Stihl 250 for £10
Tribaltree
  • Replies 25
yeh i keep looking on there, all i ever seem to find is pistons and piston rings but on cyl.
now does anyone no what the bore size of a 260 is and if i can bore the 024av out to fit a 260 piston and rings on the 024 piston rod just wondered if this may work
yeh it needs a new p&c really all i wondered if the 026 piston would fit on the 024woodboss con rod. bor the cyl out to 44 mm( is the height off the 024 piston and the height off the 026 piston the same if so then the stroke wouldnt change is that rite)i take it the small end pins are the same size to
