can i fit an hour clock to my tw125 - 2006 model
make life easier for servicing plus had new engine so be good to back up the miles when i ever sell it , cheers
Hello Dr Green.
The current TW125 machines have an integral hours clock fitted within the GX630 engine by the manufacturer Honda, all the earlier models do not have this as standard.
Earlier models without this facility can be fitted with a "Tiny Tach" rev counter/hour clock, this part is not stocked by Timberwolf but can be readily sourced from the Internet. They are currently advertised on the ebay shopping site.
This is a battery operated device that picks its signal up from the high tension lead to the spark plug and will show you rpm of the engine when running and hours run when switched off.
Hope this is useful
