you can get a 3phase electric motor fitted to your KS35 if you have 3ph power available.
you could get a phase converter if you dont. Palax do it as retrofit kit but that's an expensive way to go.
Best bet would be, get the tractor outside with the shaft through the wall as others have suggested. you really dont want those fumes and the dust mask you are using is next to useless.
