I had a Parmiter one sider on a Ford 3600. Worked fine.
A Massey would be fine, all you need is the trailer tip spool and a free return to the back end. There's no weight to this contraption and your advantage with a small tractor is that you can sneak in where bigger machines won't fit. The hardest part is setting it up level if it is an all manual machine....on, off, on, off the seat on a hilly bit of ground but hey-ho it's a bl**dy site easier than using a mall!
I now have a Parmiter 'contractor' on a Bigger Deutz and if I could find a suitable bracket I'd also make it fit my 360.
Scrap the chain and fit rope. Miuch safer!
codlasher
  • 5 years later...
Mark,
Did you find a solution. I have M35x and looking at a Parmiter type knocker and forsee the same problem.
I have a tipping transport box which is "interesting" when I tip as it lifts and tips at the same time. With that I can control with
a new valve on the tipper hydraulics. Ideally I want a method/valve to isolate the lift arms....
I don't fancy chaining the lift arms, I used the arms to pull out some big old fence posts and the tractor didn't like it
Matt
