L200 engine management light on
Happened to my 03.. Soon as you put your foot down, was told it was to do with the turbo getting clogged up.. just sold it on......
I have an 03 does it alot, I just clean out the exhaust to inlet cross over gas valve with some solvent (x4 12mm bolts 15 min job), or if on a trip just push the plunger in a couple of times and clean it when home.
I have had it come on and the engine go flat if over revved, so I have to pull over and switch the engine off for a moment, then it's ok. only prob I over revved it getting past a caravan, so now I have to follow the frigging thing for another 10 miles before I can overtake it again:lol:
