Hi and many thanks for the replies so far, i have been in touch with ifor, and its in the process of a warranty/goodwill gesture all being well, so when the dealer over here has looked at it, i will let you know the findings, but for a part to fail after so little use then this not normal and could suggest a parts quality problem. i,ll keep you informed as to the outcome.
Rust corrodes faster than use wears
update,
took the trailer along to the local Ifor dealer, they said we will give you a call in 3 weeks, 3 WEEKS I SAID, after a sharp intake of breath.. this was after i showed mechanic the fault.
i mean is it normal for someone to take 3 weeks to fault trace a defect ?
its hardly rocket science is it.
