All - the long awaited Bandit model 18SVC (screen vacuum chipper) will be on show at the APF this year.
The Bandit SVC is a very different type of drum-style chipper designed for global biomass markets, where specifically sized wood chips are often required. To accomplish this, the Bandit SVC uses a screen in the drum housing that only allows material to exit once it has been chipped to the desired size.
The screen is easily accessible and a variety of screen sizes are offered, allowing the SVC to serve the needs of virtually any end user. It also features a unique top-load discharge chute that sends chips up and over to forcibly load open-top trailers, and it utilizes a vacuum to maximize the flow rate of material going through the chipper and out the chute. The SVC will be available as a series of machines with different engine options and varying capacities, depending on the material being processed
Call us for further information or post a question and we will respond.
