wildlife act says you can not disturb birds,nests,or eggs between the 1st of march to 1st of september. unless it will cause a danger to public. to lay a hedge you would be disturbing the above £5k per item so if the bird abandons nest thats 5k for bird, nest and 5k for each egg. if no eggs found then will check nest to see what bird and will determined what no of eggs that would have been laid.
hence you do not see hedges cut or laid during this time. plus to lay a hedge when sap is rising will either stunt it or kill it as in shock.
