Help Camon 250 What Hydraulic Oil ???
wcguv
ill give them a ring tomorrow was hoping there might be a slim chance someone new so i could get it done today. Thank you for your comments :001_smile:
Buy the oil and ring them from site, I dont want to put you wrong.
Run the machine with the stress control off and if the rollers play up then with a hammer handle push and hold the bolt on the side of the pump for 10 seconds this will purge the pump. Some times after the oil is changed the spool valve will stick, if this happens then its any easy job to strip down so ill keep an eye on this thread just incase you have problems.
Welcome to the forum by the way :001_smile:
