it,s coming to work tommorow but am usin it with 13mm XTC Plus...keep it industrial...mine is still tight as a drum but time will tell...i wouldn,t want to put loctite any where near mine...it,s too Precious and shiney!
There's absolutely nothing wrong with loctite. Just remove the screw, put a dab on the end of the screw thread and puti t back in again. Provided you don't go overboard on the loctite then it won't ooze out around the screw head. And you can still undo the screw if you decide to. It's a proper solution to a problem, not some sort of bodge.
