I have an old petrol emtec 1998 and the axel is broken the machine has had a new engine put on and the have removed the id plate for some reason iam iv been told its a solid axel its 70cm between the bolts which fasten it to the machine orange plant carnt help me as the want a parts code any body have any idea were to get an axel from or is the anyone who wants to take the machine off my hands.
Hi Nottsarb
We also would need identification of the Model and serial number, both for security purposes and to establish what original equipment the machine was fitted with.
You have said the engine has been changed, it may be the axle has been changed also?
Give Timberwolf Technical a call on 01449 765820 they will try to help you with identification
Good Luck:thumbup1:
