as you will find if you search the forum all mills are different and basically it just depends on what you want to mill and of course budget. ive got an M7 which is great for long small diameter logs. i use a large alaskan for bigger stuff to either break up for the logosol mill, or slab using the alaskan. both great mills just different. i looked at a switchblade saw but they look better for larger hardwood logs and they are more expensive. also my main reason for choosing the mills is how to get the wood to the mill or mill to the logs. hope that helps a bit.
I'd go and look at and try a few mills before spending cash. It all depends on the type of work you intend to do as to whether or not the mill will meet your needs.
