Hopefully starting my CS 38 in december, closely followed by the 39. And its about time I make a wish list of things that im going to need.
So far I have seen that the stihl t200 is better than the 201, and i do have a work harness for when I used to go rock climbing that I need to check is suitable.
other than that, fire away whats the best kit at a reasonable price? boots, spikes anything.
cheers!!
Try to use as much different kit as you can on your 38, see what suits you before going out and spending any money. As for your harness,i doubt it's the right kind if you've been rock climbing in it.
Thats a good idea thanks for that! And the Harness worked for climbing, however it is a work harness by design. I will have a look for it and check to see if it will work, like helmets do you have to change harnesses after a few years?
I think they have a five year service life from date of first use. If that is not traceable then five years from manufacture.however like all climbing gear it will need to be inspected by a loler examiner every six months, potentially making it's life span less.
