Hi mate,
I have a different one its alot bigger and bolted to the underside of the chipper.
It starts fine just tried it with battery charged from home. And its been fine for years just when i changed the engine out i put it back 90% correct i think i mixed the charge wire up i could really do with a pic of where the wires from the engine connect up if you have one.
All sorted put 1 wire wrong way round for any one who may have this problem in future use a battery tested loader will tell you if the battery holds a good charge and if the charge unit is sending a good charge.
