think he's using Distel. This is not set in stone but if you’re climbing on 13mm rope then look at using a 10 mm cord. If your climbing on 11mm rope then use’s 8mm cord. This is only a ruff guide. Hope this helps
The smaller diameter cord binds tighter, when this is used on big rope you may find that you have too much bite hence using a 10mm on big rope works better i.e. less friction.
The 10mm binds less and has less contact with the rope hence less friction.
All this depends on the system you are using so horses for courses.....
