I climb on a Distel. leg length doesn’t matter some much with this knot. But the type of cord you use and how many raps you put into the knot will. Finding the right combo is the key. Don’t make the legs of the knot to long as it only waist enjoy when ascending. And know less than three raps.
This is not set in stone but if you’re climbing on 13mm rope then look at using a 10 mm cord. if your climbing on 11mm rope then use’s 8mm cord. This is only a ruff guide. Hope this helps
