Hi
I have recently replaced the hydraulic motor and have noticed what i would call excessive wear on what I would call the insides of the roller body.
What is the part number for this bit and would you advise replacing any other part at the same time.
Also do I need to take the hopper off or can I take the roller box apart under the black plastic guard.
I look forward to your advice
Thanks
Hi Treefrog
Can assist you further but need some info from you,
Please can you call the tech support help line on 01449 765820
We will need the serial number of your machine to enable us to identify any of the parts you may need.
Look forward to hearing from you
regards
TW Tech Support.
