And yes I straight felled (after clearingsome weight off)
This was before my run of bad luck and probably why my confidence was overhigh.
1st is a hung up ash --- NO I did not hang it there!!!!!
Took all day to get it down..
Second trees are two leaning Willows. The job was perfect.... Customer didn't want any clearing up done. He just wanted them on the ground.
The final Willow was a bit of an adranilin pumper as I needed to fell it off lean to avoid a fence. The tree was fairly rotten up top and getting rid of the exess weight over the lean was a bit exposed.
Final tree was 96ft and I had about a 10 degree angle to hit with the fell. No major issues if I missed but it was nice getting such a big beast spot on.
PS: Sorry for posting loads of piccies at once but I am just downloaded
1st willow i dismantled as it was leaning well over neighbours.
This was the bigger of the willows.
sorry no pictures of the willow in profile.
Ya groundy wears those all day if I'd let him. He is supposed to only wear them when climbing or silky work.
He had ran up and put a line in for the pull.
