I have just replaced the lower hydraulic motor and need to find a couple of new smaller diameter roller box springs. My machine is a 2001 and they came as standard then, but recently had to replace with the newer larger diameter ones.
The new motor pipes will not allow the new ones to fit. Can you still get them.
Thanks
Hi Treefrog
Sorry for the late response but have been away from the office.
Have checked the stocks at TW and we do not have any of the old type springs available.
Have spoken with our engineer and he advised that the new springs should fit and it could be that the bottom bolt location needs some adjusstment to enable the springs to fit and the hose fitting re orientated.
Hope this helps
regards
TW Tech Support
