Changing husky clutch spring
SiW
Can anyone give me some advice on changing clutch spring on a 346 Xp please. 2002 model. Thanks
Decent set of fairly narrow nosed pliers, get one end of the spring on then the other and gently tap down into place - first few attempts might frustrate you but it's not bad to do. Watch out for it pinging off before it's seated down properly.
I've found external circlip pliers (ie squeeze and they open) a good tool for this job.
This is how I do it if the clutch is off: using the pliers, open up one of the springs, but don't take it off, just wedge it open (combi spanner is just the right size for this). You can then open up and take off the other spring without the first spring interfering. The rest is straight forward.
Edited by Quickthorn
