this pic os of a fungus the customer pulled off of a mature beech tree...its old, slimy and hard to ID. looking at the symptoms on the tree its a root rotting fungus but im unsure which. the bracket was apparently growing right at the base of the tree. measures approx 40cm across and is fairly heavy too
If that the same tree/fruiting body in both pics guys then its either Meripilus giganteus or at a stretch Grifola frondosa. G. frondosa is not so common on Beech as M. giganteus but both form an intense white rot on the underside of structural roots. Either way bad news. :(
