As per the title...:001_smile: Our harnesses carry manufacturers markings as well as serial numbers and so on..other items like our ropes (climbing ropes/access lines) may not be as individually marked and yet the information (spec) is easily sought, either online or at the point of sale...
What I want to ask...
If rigging ropes are required a safety factor of ten (10)
What safety factor (sometimes referred to as cycles) do the LOLER regs (1998) require our climbing and access lines meet?
( I know..CE marking and SWL in excess of 100 kgs of actual load..not what I am asking though )
TIA
Climbing kit must be 22kn minimum which pretty much means fine for use and the allowance for a rescue.
Even if you used a 3 ton sling in your climbing kit it would now be deemed as 1 Person ( with the allowance for rescue)
Hope that makes sense
