Where applicable please could you list your chosen application for the knot in question, size cord you prefer, length of cord(or loop in some cases), pros and cons, etc etc...anything you can think of really. Thanks
  • 4 weeks later...
The Flemish Bend is used to join two ropes together of similar diameter. It is fairly secure but there are better options to use in a life support configuration. The Flemish Bend is also prone to jamming, so again there are better options to use in a high load scenario such as a pull line.
