Sequoia legs
Lancstree
Been up a large pop today in my new Sequoia harness and its been a bit rough on the legs. Anyone else have this? I'm used to the slightly chunkier leg loop pads on the butterfly so hopefully its just a case of getting used to it. I do like the position of the D rings and gear loops better than the butterfly and the back pad seems pretty comfy so far. It just seems like the BFII was slightly more bearable to hang in - not that I hang around all day!
My sequoia hurts my legs a bit when hanging full weight in it. But i am used to it now. I like the way the leg loops sit quite low away from the family jewels! best harness ive had. theside tool strops are a bit weak though.
I find the leg loops really nice to work in, far less restrictive then having a bar like on the butterfly. Occasionally when you have to put all your weight in it in an upright position I find it raises up which can be uncomfortable. Once you get into a work position though IMO its the best harness I've used.
