Hi Forum
any ideas on s solution to a problem i have with my blower. its a back pack type Echo PB260l the drama is every time i use get it out to use it it will not start, it takes 3 attempts o pouring fuel mix down the plug hole and then it starts and runs fine.
Put it away until the next time and i have to do all the above again any ideas what it could please??
thanks
Common starting problems are: -
Fast idle setting not engaging correctly
overly weak mixture
Choke not sealing the carb correctly
Low compression
Carb needs cleaning
Tank breather not letting air in
Flywheel to coil gap too large
Fuel lines gone soggy
Fuel filter blocked
Exhaust port or muffler carboned up
These are but a few but worth a look
