hello im new to this forum i have an entec tw125 hp ,did a bit of a school boy
error! went to change the ignition switch with one i brought off ebay, took the old one off and cut the wires out of the original connection block, thinking it would be a piece of cake! to put them in the right place but oh no!,i would be greatful if some one could tell me where the wires go! on the new ignition switch
or put them back on the original switch! which was working but had a snapped key! many thanks, john.
Hi John
Woops : put this one down to a Blooper.
To answer your question we require some further information from you as all we do in the manufacturing process is tap into the internal wiring of the engine.
If you give us a call on the Tech support line on 01449 765820 and supply us with either the serial number of your machine or engine we can investigate the matter further for you, and if we are unable to assist we know a man who can.
Look forward to hearing from you :thumbup:
TW Tech Support
