my engine on my rayco 25hp is nakard stripped it down weds and its buring oil and loosing revs opened it up both sides are full of engine oil. theres a crack slash chunk missing inside but i dont think thats why its leaking oil into the chamber, i think its the rings gone but the hole is a concern wheather i can put back together with new rings and will it work ill upload pics later its got a chunk missing just under the piston chamber deos any one have a engine kicking about want a kohler again even a bigger engine size will be ok or a broken one so i can use all my iner parts or do you think it would work if i put back togther
cheers paul
