Hi Everyone,
Has anyone mounted a reverser for the PTO on a U900? I'm prepping for it, and wanted some tips. I have a BIMA reverser. If I could post a picture, I would do so for the perspective. until then, use your imaginations I suppose. It has one input female, then directly on the opposite side, is the 1st male PTO shaft, rotating the normal way.. then directly under that one, or beside that one, depending on the orientation, is the secong male PTO shaft, that has the opposite rotation.
Around the front, lower, reversed PTO are 4 threaded holes. Then on the side the pto slides onto, is another pattern of threaded holes, but perhaps 6-8 holes here.
It appears I will mount it from the rear threaded holes, to not interfere with the shaft.. but any feedback is super great. Thanks in advance! -ACUF
