Lucky you didn't get a big belt off the cap:001_huh:
Probably the black wire has come off the spade connector behind the front AV mount or the earth wire has fractured or come loose - fairly easy fix - you can meter them to find out if the wire is broken.
Most people pull the choke on to kill the engine if the stop switch fails:thumbup1:
thanks for that thought about the putting the choke on after i'd done it, just me not thinking!!
