would there be any problems/issues with using some left over cobra to make up a loopie sling or whoopie sling? to be used for light lowering, nothing major. lots of work in cbd area so everything has to be lowered due to cars, buildings,people etc...
Cobra is polypropylene and will begin to fray more or less straight away. It will look hairy within a few uses and break soon thereafter. Its poor abrasion resistance is why you use a sleeve where it goes around the limb when bracing.
Furthermore it has no stretch (for shock absorption) and will give up the ghost with no warning whatsoever - to provide stretch you have a separate, shock absorber insert in bracing setups.
Bottom line - bloody dangerous, so no.
