338xpt oiler
emeral-landscapes
i bought this husky i think as a bet, as i always buy stihl, and must of had a brain storm to buy husky junk.
the oiler keeps packing in.
ive had it apart 3 times (which takes a while ) cleaned the oiler, new plastic drive gear etc but nearly instantly it stops oiling the chain and plastic drive gear is knackered......
any suggestions before i put it on the next bonfire and laugh as it burns and melts slowly
You will find that someone has fully undone the adjuster and then done it up without pushing the oil pump gear shaft in to the pump before doing up the adjuster.
This bends the shaft and will strip the pinion (worm drive) in two seconds.
You will need to take the pump off and remove the gear shaft (the one the pinion drives), get it on a flat surface and see if it is bent, if it is, you can straighten them but it isn't easy.
This is one of the weak points of the saw - otherwise they can be little belters.
If you get stuck and want me to look at it then feel free to PM me but would lay money down this is the fault.
PS - don't knock Huskys - they are good machines and in my experience it is misuse and lack of maintenance that kills them!
Spud
Edited by spudulike
in fact spud, also after a small stihl. would part ex all my top handled saws and parts for the above if its of interest to you
Been out of the country so sorry for the late answer - it depends on what you want and what you have to offer in parts - the side covers for these saws are like gold dust - you can get new spares but the whole assembly would be expensive.
Send me a personal mail to take this offline with what you are proposing and will see what works.
Cheers
