Sticky firewood properties?
Rentachimp
Should we have a Sticky forum on which woods are best for Housefires and Stoves?
45 members have voted
  1. 1. Should we have a Sticky forum on which woods are best for Housefires and Stoves?
    • Yes - let's have a sticky forum on which woods are best for Housefires and Stoves?
      33
    • No, I don't think this is a good idea, you whiney young man.
      5
    • Really? You're not an Arbo anymore?
      1
    • Stop bothering me; I'm trying to keep my fire going.
      6
Does anyone know how much timber per annum you could reasonably expect from a coppice on a per acre / hectare basis?
really depends on the age,state,species and prior management/neglect.i'm currently coppicing every winter in 10 acres of ash which aint been touched for donkeys and getting about 30 ton per acre still leaving some good standards and a decent canopy.on the alder thing i seem to recall it was used for something to do with rivers,moorings etc because apparently it doesn't rot in water,can anyone else elaborate?
  • Replies 46
Hardwoods normally have a yield class of around 4-6. If you stretched this to a coppice situation, you can expect an increase of 4-6 cu. m per year per hectare, so a sustainable production would also be 4-6 cu. m per hectare per year. Your 10 acres (about 4 ha or so) of ash is probably growing at a rate of around 16-24 cu. m per year. Ash is pretty light, at about 860 kg/cu. m green, so you'd expect 14-21 tons/year to be a sustainable yield.
We coppiced an area (leaving the biggest as standards) last season that was supposed to be 1 ha. It had probably been coppiced about 15-20 years ago. We reckoned the resulting stack was 70-100 cu. m (I'd go for the smaller figure, because it wasn't all straight)
  • 1 month later...
