carving sprocket?
dreadtrees
as long as the pitch and gauge on the new chain is the same you will be ok, if the pitch is different then you will need to get a new sprocket for it
So, as the MS 180 is "born" with a 3/8" pitch "Picco" (low profile) chain (and matching sprocket), you'll be alright if the carving chain is also 3/8" pitch.
If you have a 1/4" pitch carving chain, you'll need a new 1/4" pitch sprocket.
