Anti-vibration mounts
Arctostaphylos uva-ursi
  • 4 months later...
hi, I work for a company who specialise in Rubber Anti-Vibrations Mountings / Vibration Isolators.
If you would like some guidance on the type of rubber av mounts to fit on your application, or the installation method, you can contact them on 0116 2461261.
The companies name is AV Industrial Products Ltd. They get involve with most vibration control requirements, basically offering a technical back-up service aswell as selling the actual products.
They sell every possible type of mounting, from simple bobbin type mountings, captive / failsafe anti vibration mountings, spring mounts, rubber sheets.
I hope this helps you.
Regards
