There's a screw underneath the saw (turn it upside down) that you can turn to turn the oiling amount down.
But a tank of oil to a tank of fuel is about right when the oil is turned to max... surely not that expensive on a 200t though! :confused1:
Sorry Matey - the adjuster is on the top of the MS200T, undoing the screws on the bottom will drop the exhaust or remove the rear cover:confused1:
The saw only oils when it is spinning the chain and the adjuster is typical of most pro saws - the end of the shaft is cut at an angle and the adjuster just pushis it further in to the pump.
Spud
