Use one everyday at work, brilliant tractor. Most of the work it does is powering the processor, but it does do some forestry work and is excellent. Was the only vehicle to start easily in this cold spell. Was also the only vehicle kept outside. Ours jumps out of 4 wheel drive which can be absolutely terrifying. Nearly rolled it a couple of months ago due to this going down a steep bank with a trailer on. Ended up with the trailer jack knifed and on its side so could be worse. Im not sure if this is a common problem with them or if it is just ours. Either way something to keep an eye on.
What are you planning on using it for?
Ella
