i have provisionally booked a demo of used 15m3 machine with a loading crane next month. does anyone have any experience of these? i've read they are far superior to the seko machines, is this the case?how do you charge the customer, day rate, volume, hourly, per job etc and what is the going rate?Are there any issuesa to be aware of buying used ecogreen etc etc. any advice, suggestions welcome. cheers dave.
My boss recently purchased one of these, have yet to see it really working, but what little it has was done very well. Helluva machine :thumbup1:
There's talk of putting the arisings through a grader of some sort to remove things like chunks of fence post and long stringy bits, otherwise its not compost!
No idea of charges. Can let you know more about its workings when I see it in action, good luck with the demo
  • 1 year later...
Seko machines come in two builds Green or Green & Compost the G&C is the strongest machine which will chop and mix material up to 4'' the blades and the machine are built in special hardwearing steel, so always compare like for like!
