frankly the brake setup on the carlton 900 is rubbish, it engages well, but disengaging it is nearly impossible, as the cable nearly allways seems to bend,
ive added a spring attached to the caliper then attched to a bracket on the frame to help pull it back
have to see how well it works in the field, but seems to do the trick at the moment
