If it sparks then then its maybe fuel not getting through or air filter blocked. Clean the filter first as thats the easiest, then try it.
Old fuel in your carb may have gummed it up. Can you smell fuel and does your plug get wet?If not it might need a carb kit. Easy to do with a systematic aproach, otherwise your fuel line or impulse hose may be shot.Both simple fixes.
