im over in st helens which is about half an hour from upton. You can come and dump chip here on one of our fields
Cheers for the offer Rob. I'm about half an hour from Chester myself. Was hoping for somewhere a bit nearer if possible?
cant suggest anywhere to be honest, the offer is there though if you need it!
Many thanks, may take you up.Will pm when job is confirmed.(Awaiting survey for water mains) right under oak stem which requires grinding out. What joy!
just hope for a stinking hot day and if you do hit them then it wont seem as bad!
as long as you have a 4x4 you will be able to get down to our chip pile!
