In need of scrap metal!!!
TArrryan
As the title says I am In need of scrap metal, however I am not after any old metal, what I'm after is smaller pieces of metal in interesting/different shapes.
What I like to do In my spare time is weld them together to make scrap metal statues.
Down is an example of one I'm working on now!! Its still unfinished, I have to make a head, tail and flesh out the legs. Ill also rebuild the hands later on as well, I didn't make much of a effort and now I'm regretting it. see if you can recognise any of the parts ;)
If you are in the new forest (or a little further afield) please let me know if you have any small pieces of scrap laying about. I'm in desperate need now as I have exhausted my current stock of parts!!
Thanks for reading
Ps, although I didn't have anything in mind when I started, I have now decided it looks like Godzilla for those who remember the beast!
Depends on the type of scrap you have got, if its small pieces of plate metal and nuts/bolts then it would be a bit far. However for items like springs, small mecanical pieces, odd shaped bits of metal then i would be happy to traval to you.
I dont suppose a picture would be possible at all?
Just as a example of what im using here is a list of some of what i used in the above figure.
Snail ajusters (landy brake part)
Gubbin pin (spelling?)
Big end
Big end bolts
Chainsaw chain
Damper spring/brake caluper spring
Crankshaft from dads hedge cutter
Bits of landy tappets
Some milling offcuts from a friend
Hedge cutter blade (not shown)
Coach bolt
Etc etc
Hope that gives an idea of what im after and thanks for your reply
