Just an update on this, started my saw the following day after a thorough cleaning and all seems ok!
..... I remain slightly skeptical but its been fine for a few tanks now. Thought it would be worth mentioning that someone i spoke to said due to the heat air can get forcd into the carburettor making the mix abit funny.
Needs a abit of a working to blast it through back to normal.
So if anyone has a similar problem it might be worth percerviering for a while just to make sure it isnt that. May save you a few quid for an unneccasary repair. :thumbup1:
I've just a couple of dats ago fix the same problem.... But I don't know the cause :) but I can tell you that I
Cleaned the air filter
Emptied the fuel tank and blew it out with the air line
Cleaned the fuel filter
Stripped the carb off and mildly blew it clean
Put carb setting back right after messing with them like a man possessed cause I had only took one Ms200 doh!
Put it all back together and hey presto working again
Good luck
