:001_tt2:
Forget buying the husky teeth there a total and absolute rip off!. Standard L + R finger teeth will fit that grinder no problem. Saturn use to sell them for a 2-3 quid each.
The only difference is the standard teeth have a shorter locating shaft. The husky ones had a pointless pin at the opposite end of the tooth which meant you had to take the whole assembly apart to replace them.
Standard teeth you can just loosen the bolts on the wheel and slide on new ones.
Ive only ever used standards on mine.
So you don't even need to change the pockets?
Excellent! :thumbup:
