I saw some years ago an autmomatic punch device that delivers a spring loaded punch at a consistent force. It was used to record the resistance at 10mm intervals of a steel probe entering a tree. This could be using in a simialr way to a resitograph to map areas of decay. Are these still available? if not where could I find a device which delivers a consistent force to use in a similar application?
Google destructive wood testing, telegraph poles. They are available still on the net I used one in some research trouble is that you only find decay near the surface or you drill quite large holes in the trees, which sort of defeats the object.
Sorry no luck still, do you have a link? Surely to could make up a narrow probe .5mm wider than a narrow twist drill? Or is there some other reason why it would need to be a larger hole?
