Hiya Peeps,
I'm part of a voluntary community group that is planning to do a a big spring clear up of a local green space blot on the landscape in my local town during the forthcoming bank holiday weekend. Assuming we can get rid of the smack heads and the teenage p**s heads for long enough! :sneaky2:
It would be enormously useful if I could borrow for 24/48 hours a petrol strimmer (ideally with a brush cutter head also). I would of course arrange pick-up and return of the same and vouchsafe that it will be returned in the same condition it was picked up in or make good any repairs should anything untoward happen. (Which it won't).
If you can help please get in touch. I'm based in Stalybridge, Tameside area, so closer the better please. Obviously I'll not be schleping backwards and forwards to the Outer Hebrideses for one.
Many thanks in anticipation folks,
Rick
I can lend you a husky one, nothing special but does the job. Not sure where the blade is for it tho so you may have to put up with cord. I'm heading up to Durham on the sat eve/avo so could drop it off then and you can bring it to me when your over a couple of wks after. If I remember I'll txt you at a more reasonable time tomorrow.
R
