Ms 200,200t carb.
High Scale
If you have one of these saws bought from around 2004 onwards have you had running problems?
Check your carb model, if it is a D type carb, (First line on the carb should be something like F61.D) If it has this carb see if your dealer can replace it, I have been informed that the D type carbs are dodgy, possibly due to the brass fuel jet now replaced with stainless steel on the newer model carb.
