ernst does doe new holland 32vg
so as long is the code is 32 which i think hollands is system 32 that is spot on and we use it.
questions to mike how much is a pipe from hydro tank to hydro pump and all other pipes on a 2001 chipper 24/150:confused1:
Hose tank - pump HY2750 = £28.95. We dont buy our hoses from TW we get them made. Allow £20 each for the other 5 and that should cover you.
Regards
Mike.
Regards
Mike.
Mike got a tw24/150 will be looking to do bearing change can you pm me prices to include the hose change and also the hydro motor spline drive top and bottom
Lower roller sits low towards the motor side ??
How much is a pull start for the honda engine
Cheers
