As some of you out there will know our local county council are in the process of letting a new framework for tree surgery. Pricing is done by various operations in different size class and categorey of tree. There are 5 categoreys and in each cat there is a range of size classes, so for instance a 18m tree with a diameter at breast height of 0.5m (18 x 0.5 = 9) is a size class 9 which falls into a cat 3 tree. this is not a problem, but it could be any species, so is there a graph that shows various size classes of tree for various species. we've worked out the averages but a check is always handy.
