MS260 hot running problem
Graham
I had this problem with an MS180,
It was finaly solved after much messing, the lower crank case half had a small crack in it just over the seal area, when the motor warmed up the crack opened and the mixture went lean.
One bottom crank case later and its fine,
This fault could only have happened new from Stihl, had me scratching my head for a while :laugh1:
