Hi
The unit is covered by the warranty and should be taken back to the dealer from where you purchased it to have it looked at, you may invalidate any warranty if you try to take it apart.
It does sound like a fuel problem, and the advise given in the threads is sound, dirt & debris does find its way into the tank even though it is a new machine, if you take the unit to a honda agent they should be able to sort it for you,
Was advised of your problem from others, if you have a specific question please post it on the Timberwolf Forum as it is monitored daily.
regards
Timberwolf Tech Support
